York hydronic unit heater
Yooperdude
Member Posts: 2
I am trying to determine the btu and hydronic coil specs in a York hydronic air handler.
Model # YUUH150
It has 3/4" S&R lines, (no DX coil) and I have more info beyond that I can share if needed.
Thank you!
Model # YUUH150
Thank you!
York
I couldn't find anything on a Google search and the York website has no search engine.
Their residential selection of air handlers has nothing with that serial number.
http://www.yorkupg.com/NewCatalog.asp?t=r&id=3
And they don't seem to have any commercial air handlers listed.
It must be an older, unsupported model.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thanks!
This is a commercial unit/ceiling mount.
This is a difficult manufacturer to get any info from, if they indeed made the unit.0 -
A 3/4" pipe
is good for 40,000 BTUH or so. If you can't find anything on the unit, you might go with this figure.All Steamed Up, Inc.
Consulting0
- 120 Geothermal
