York hydronic unit heater
Yooperdude
Yooperdude Member Posts: 2
I am trying to determine the btu and hydronic coil specs in a York hydronic air handler.
Model # YUUH150
It has 3/4" S&R lines, (no DX coil) and I have more info beyond that I can share if needed.
Thank you!
  • York
    I couldn't find anything on a Google search and the York website has no search engine.
    Their residential selection of air handlers has nothing with that serial number.
    http://www.yorkupg.com/NewCatalog.asp?t=r&id=3
    And they don't seem to have any commercial air handlers listed.
    It must be an older, unsupported model.
  • Yooperdude
    Thanks!
    This is a commercial unit/ceiling mount.
    This is a difficult manufacturer to get any info from, if they indeed made the unit.
    Steamhead Member Posts: 18,502
    A 3/4" pipe
    is good for 40,000 BTUH or so. If you can't find anything on the unit, you might go with this figure.
    Consulting
