control valve
Icowboy
Member Posts: 2
Looking for a 3-way or bypass valve for wood boiler hot water heating system. Prefer 110v, full flow, slow acting. Any suggestions?
Are you looking for the main control or the power fail dump valve?
I use AutoMag's for the dump valve. And I use the packages from HS Tarm or Bioheat USA or whatever their name is now, for the 3 way control valves. I think a company called STSS makes their control packages.
Is this a wood/fossil hybrid system?0 -
need 3-way valve
I have a wood fired boiler that uses a bypass valve from house to a storage tank to help control the heat. I need suggestions for a full flow bypass or 3-way valve, 3/4", 110v preferbly.0 -
Have you tried
Belimo? They have a full line of valves and actuators for just about anything you want to do."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
