Indirect Water Heater lifespan
veissman_Bob
Member Posts: 48
I'm trying to decide between a Vitocell 300 series 53 gallon horizontal indirect tank, a Triangle Tube Smart 60, or a comparable WM tan k. All are stainless steel and all apparantly have a lifetime warranty. Should I be able to expect a 30 year life out of all of these tanks, or is the Viessmann the only one that'll last that long? If the Viessmann truly is the only tank to last that long, I'd gladly pay the extra price up front (it's double the cost).
tanks
I believe Viessmann is the only tank that is a true lifetime warranty. All the other tanks are pro-rated after 8 years. Viessmann's V-300 last I heard will replace the tank no matter when it fails.0 -
I have not installed a Veissman
but I have installed both of the others and replaced them both through warranty. company stood behind them even with questionably water chemistry. If the water is harsh enough you will need to replace any of them. Check your water quality no matter the tank you choose.Cost is what you spend , value is what you get.
cell # 413-841-6726
I second James' post.
I have used all three and the Vitocell 300 is the only one without a prorated warranty. They use 316Ti stainless. The Ti stands for Titanium. The others are great tanks, they use 316L. I have had a few problems over the years with the TT/WM tank within a tank design. Minor though. The only leak that I have ever had on a Vitocell was a purosity issue on one of the nipple welds. Replaced the whole tank. That is one out of a bunch. 98% of mine are on well water with varying water conditions.
Just curious, are you going to stack the boiler and dhw with the horizontal?0 -
Sorry Duplicate Post.
I'd like to......
To answer the Q above, I'd LOVE to do that but from what I can see the piping coming out of the bottom of the Vitodens (boiler supply, return, condensate drain) won't allow me to stack it. I thinking of mounting the boiler on the wall and having the water heater below it, but not necessarily stacked on top of it.0 -
Your correct.
The Vitodens can only be wall mounted.
I used to stack a lot of the Vitolas with the Vitocell H-300 under them. Great set up.0 -
What about Burnham?
Anyone use the Alliance?
http://www.usboiler.burnham.com/products/water-heaters/alliance-sl/index.php
It appears not to use stainless of any variety.0 -
There Is NO Comparison
Let's not forget that coil is made of the same 316-Ti as the tank. Tank has a much larger coil sqft surface, extremly insulated, has a spot for a recirc pump, recovery rates blow away the competition....Did I say I am partial to Viessmann
It is a true lifetime tank.There was an error rendering this rich post.
