Burnam ES2 vs. Buderus GC124
in Gas Heating
My husband & I are in 70s and are replacing 2 boilers. The chimney will be relined. We want to know what makes most sense for us in terms of efficiency and maintenance. Thanks
That Depends
Not enough info to say either way. What was the heat loss? Would a condensing boiler make more sense since you wouldn't have to pay the expense of lining the chimmney? What are the heat emitters?There was an error rendering this rich post.
Or to look at it from another perspective
is there a safe place to exhaust a condensing boiler? If not, a relined chimney is the way to go.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
