Roth Tank Capacity & Specs
D-man
Member Posts: 17
in Oil Heating
1) What is the <span style="text-decoration:underline;">effective</span> capacity of a Roth 275?
2) How far does the Roth Vent Alarm drop tube extend into the tank?
3) How far from the tank bottom are suction lines typically installed?
spcs
1 about 250-260 gallons
2 about 4 inches
3 about 2-3 inches0 -
Roth Tank
I installed a Roth 1000L/275 gal last spring - outside and put it in an enclosure that is insulated.
The one thing advised is to use a rigid suction tube from the top port and not the flexible tube/line.
Since mine is outside I installed a Rollie Tank Heater that has a SST heater element in the draw tube that extends to about 2" off the bottom.
So far very happy and the cost delta to the steel tank the Roth was $350 more. but should last a long time.0 -
Cost of Roth tank
How much would a 400 gallon Roth heating oil tank usually cost without installation?0 -
Cost of Roth tank
- 120 Geothermal
