Replace old heating pipes?
choyu
Member Posts: 1
What pipes are these? The house was built in 1950s and have a hot water system. Is it worth the money to replace them?
Thanks in advance
Thanks in advance
Heating Pipes
Those are threaded iron pipes with Monoflow tees and copper runouts to the radiators. One of the pictures shows a galvanized runout through a wall.
As far as replacing the piping, read this thread first and come back if you have any more questions.
http://www.heatinghelp.com/forum-thread/135783/Hydronic-heating-system-how-long-will-the-pipes-last8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
