How do you protect......
aluminum
they make aluminum snap fit sleeves for thisThere was an error rendering this rich post.
CP 10 Adhesive...
Trowel or hand apply, finish with a brush. Use to come in White or Bronze colors. Its water based, so you can probably color it however you want.
Dries to a rough raw hide finish similar to a vinyl cover, except it is UV resistant.
http://www.fosterproducts.com/pdf/ChildersSelectionGuide.pdf
Don't get any on your going to Church clothes... It don't easily come out.
ME0 -
wierd
I could have sworn I posted to this already.
we use stucco embossed .020 aluminum, with aluminum elbows and such. all sheet metal screwed in place, and paint to match. but that said, we only use foam (HT) insulation, no fibreglass outside.
should be able to get it from your insulation provider.
karl0 -
Check out Dr. Ben's website
You have to jump thru a few hoops to see a good video about insulating a collector loop, but it's worth it:
http://www.solarhotwater-systems.com/
The second of the "Top3 Mistakes" is poor quality on the collector loop insulation.
He mentions that fiberglass can get wet outside, but I think most foams have the same potential problem.There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
