Primary/secondary hydronic system
edow
Member Posts: 17
What is a to the point description of the primary/secondary system?
In heating systems
a P/S system allows two separate hydronic circuits to work independently of each other while still allowing controlled transfer of heat from one to the other.
A corollary explanation is that when a circulator is operating in any one circuit or both, their operation will not affect flow in the other circuit."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Double Post
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
