formula for finding GPM circulated
edow
Member Posts: 17
what is the formula for finding GPM circulated?
Do you mean
recirculated in a domestic hot water system or a hydronic heating system?"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Wouldn't it be simpler...
... to look at the pump curve? All modern pumps come with one. It tells you the flow rate at different conditions of flow restriction. Think of it as a visual equation.
Yours, Larry0 -
For a heating system:
GPM = Btu/(Delta T x 500)There was an error rendering this rich post.
Hey Eric....
Mr Barba would be so proud....
Terry O0 -
which eric?
which eric are you talking about and if its me huh?0 -
So....
How do you figure the BTU's ? ;-)
ME0
- 123 Chimneys & Flues
