formula for finding GPM circulated
edow
edow Member Posts: 17
what is the formula for finding GPM circulated?
  • Brad White
    Brad White Member Posts: 2,399
    Do you mean
    recirculated in a domestic hot water system or a hydronic heating system?
    -Ernie White, my Dad
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,143
    Wouldn't it be simpler...
    ... to look at the pump curve?  All modern pumps come with one.  It tells you the flow rate at different conditions of flow restriction.  Think of it as a visual equation.
    Yours,  Larry
  • EricAune
    EricAune Member Posts: 432
    For a heating system:
    GPM = Btu/(Delta T x 500)
  • Terry O
    Terry O Member Posts: 67
    Hey Eric....
    Mr Barba would be so proud.... :)
    Terry O
  • edow
    which eric?
    which eric are you talking about and if its me huh?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    So....
    How do you figure the BTU's ? ;-)
    ME
