sheetmetal codes
mikel0211
mikel0211 Member Posts: 13
can anybody help me find the codes for this new residential sheetmetal stuff.how much flex can be used, insulation values etc.
  • Brad White
    Brad White Member Posts: 2,399
    edited March 2011
    SMACNA Upside the head.
    SMACNA promulgates the sheet metal standards for the industry, I would start there. If it is an actual code versus a reference standard issue, most states subscribe to the IBC and by extension the IMC and the IECC (International Energy Conservation Code).  I am not sure where the residential portions are broken out nor am I sure that this helps you. But your local SMACNA chapter would be where I would start.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • MikeyB
    MikeyB Member Posts: 696
    edited March 2011
    Brad
    Brad, your Title for your post is exactly what I needed to see at 5:30 am, thanks for making me laugh
  • mikel0211
    sheetmetal
    ok thanks brad
