question for heating professionals
bob eck
Member Posts: 930
Lets say I am a home owner and I am looking at buying a high efficiency gas boiler system from you. what are the top three reason I should go and buy the job from you?
That decision
That decision would be up to you after you had a chance to see my estimate versus the competitions. My estimate would have more then one choice for you to make. It would include that I have done a room by room heat loss of your home and that I calculated, using your existing radiation, a proper heating curve. Those will also give me the necessary tools to show you savings and payback.
Then we get into the options. I provide you with the benefits each system type and hydronic products I choose for you. From there it's your choice as to which option you choose and I am there to anwser any questions you may have. Heck I'll even tell you to visit heatinghelp.com to get unbias advice. You have to separate yourself from the competition. When taking this approach I find that it allows the customer to really start comparing what services they are going to get from you that are different then the competition.
I think your first impression and what you do in the home on that visit is what generally tells the homeowner if they want you or not. The estimate may in some cases be second.There was an error rendering this rich post.
Check this out...
As Dan has said a cajillion times, "It pays to wander off the Wall"
http://www.heatinghelp.com/article/182/The-Business-of-Heating/219/One-Hundred-Reasons
ME0 -
Powerful
Now that is creative and powerful.There was an error rendering this rich post.
Powerful
Your last line........
...says it all, Chris.There was an error rendering this rich post.
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
