EZ Water....
kcopp
kcopp Member Posts: 4,630
Hi All.
 I am inquiring to see if anyone out there has experience w/ the EZ water treatment system that it all the advertising rage on talk radio. Does it do what it says? I have a friend w/ poor water(hardness) that has had a softener for years now but the salt needed to get it to run right is killing the pipes and equipment. Water tastes terrible. water treatment co. says it is working right but IDK.
So before I spend that kind of money i am throwing it out there. What say ye!
ty,kpc
  • Gordy
    Gordy Member Posts: 9,546
    Water boss
     Is what I use.  Its still a salt softener, but it only regenerates as needed, not at set daily times needed or not.  My city water hardness is 28 grains with out treatment.
    If you are looking for different softening media I have no experience with their effectiveness.
  • kcopp
    Not a softener...
    http://www.easywater.com/
    No salt to add...
  • icesailor
    icesailor Member Posts: 7,260
    Another miricle product:
    Wow!! Another miracle product.
    You need a better water softener. You need one that is metered and uses only the amount of water it is programed to use before regenerating. Plus, you media bed (Cation) is probably shot and needs replacement. You can also use Potassium Chloride instead of Sodium Chloride.
    How's the PH of the raw water? If the PH is low, water softeners don't work very well. You may need a neutralized first.
    If you get that kind of scuzz inside your water pipes, you have the wrong filters for your conditions.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Sounds like...
    A Clear Wave conditioner.
    http://www.fieldcontrols.com/clearwavehd.php
    Although I have no personal experience with this particular conditioner, I do have substantial experience with magnetic conditioners, and they do in fact work to eliminate hard water scaling.
    Field Controls can't afford to be selling junk, so it MUST work.
    ME
