Martco
I have very eatic super heat on a fixed bore system...pressures are 60 suction head will constantly dance.....superheat will be as much as 20 and as low as zero....what gives
  • Techman
    Techman Member Posts: 2,143
    edited March 2011
    superheat
    What application is this for? Ambient temps?I would lean towards an undercharged system or a restricted liquid line. What is the design freon and what freon is in the system?What are ur pressurers?
  • ddlong1286@yahoo.com
    ddlong1286@yahoo.com Member Posts: 139
    Bad airflow?
    I am with Techman, a little more information would help tremendously!
    But a guess is a guess, check your airflow, bad capacitor on blower motor, bad bearing on small self contained, what ever would make your airflow inconsistant.
    Don in MO
  • meplumber
    meplumber Member Posts: 673
    Gotta add a third to that guess.
    I would start with airflow as well.  That is the normal culprit with erratic superheat.
    More info would help us narrow it down.
