Martco
Martco
Member Posts: 1
I have very eatic super heat on a fixed bore system...pressures are 60 suction head will constantly dance.....superheat will be as much as 20 and as low as zero....what gives
superheat
What application is this for? Ambient temps?I would lean towards an undercharged system or a restricted liquid line. What is the design freon and what freon is in the system?What are ur pressurers?0 -
Bad airflow?
I am with Techman, a little more information would help tremendously!
But a guess is a guess, check your airflow, bad capacitor on blower motor, bad bearing on small self contained, what ever would make your airflow inconsistant.
Don in MO0 -
Gotta add a third to that guess.
I would start with airflow as well. That is the normal culprit with erratic superheat.
More info would help us narrow it down.0
