Indirect Water Heater system problem
Jer
Member Posts: 3
My 10 yr old bock indirect water system started putting out a hot water flow through a pressure relief drain. The "rookie" plumber showed up and tried many different things including a new relief valve, installing a new pressure expansion tank, then announced that we needed a whole new sidekick water tank -big bucks. Is there something that could be wrong besides the tank? Help!!
Pressure
What is the pressure at?There was an error rendering this rich post.
Pressure
It is apparently too high - 40. One release valve goes at 35, the other at 70. Jer.0 -
PRV
One is 35psi, the other is 70psi is what your saying? Where is the 70psi one??There was an error rendering this rich post.
is the relief valve
on your boiler the one that is popping? If that is the case, and not the 100xl, the coil in the indirect sounds to be bad. If that is the case, it is not repairable, and the tank must be replaced.0 -
You're right
You are right - they determined that the coil in the water tank had a leak. They have already replaced it. We decided to go with a Lochinvar stainless steel tank. Many hours of plumbing to get it installed, but all seems to work now. I don't even want to see the bill - but hopefully this will be the last time we have to replace the tank! Thanks for your input.0
