hydronic systems contamination
lakeside
Member Posts: 1
are smaller hydronic systems (by water volume) more likely to get contaminated?
Not particularly, why?
I mean, if you have a given amount of contamination introduced to a smaller volume it will be more contaminated than if diluted in a larger volume (obviously). But all things being equal, volume should not be a factor in attracting a higher degree of contamination than a different volume.
What prompts the question? What are you experiencing?"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
