hydronic systems contamination
lakeside
lakeside Member Posts: 1
are smaller hydronic systems (by water volume) more likely to get contaminated?
  • Brad White
    Brad White Member Posts: 2,399
    Not particularly, why?
    I mean, if you have a given amount of contamination introduced to a smaller volume it will be more contaminated than if diluted in a larger volume (obviously). But all things being equal, volume should not be a factor in attracting a higher degree of contamination than a different volume.
    What prompts the question? What are you experiencing?
    -Ernie White, my Dad
