Older steam boiler wiring repair question
SteamRoller
Member Posts: 12
I just moved into a house that has a Utica PEG-187AS that was installed in 1983. Some previous un-un-unskilled homeowner "fixed" the wiring leading to the boiler.
What I thought was the emergency switch at the top of the basement stairs, a pre-1955 or so switch box with fuses, turned out to only turn off the automatic water feeder. With this switch off, the boiler will still fire.
I'm new to controls, though I understand the basics. The boiler has a standing pilot, and I think I have a millivolt system, because with the main house breaker turned off, the thermostat can still start the boiler.
With this in mind, I would like to install an emergency switch that prevents the boiler from firing. Lacking diagrams (the boiler manuals are long gone, and the Utica website doesn't have the older manuals), should I just interrupt the low voltage thermostat circuit with a switch?
if it is a millivolt system
and gas emergency switches are not used. If you want to stop the boiler from firing then you would need to turn the gas valve to pilot only.Cost is what you spend , value is what you get.
cell # 413-841-6726
Thanks!
Thank you!0 -
old steam boiler
you could wire in a switch to break the signal from the thermostat0 -
old steam boiler
I would
not suggest wiring any switches intoa powerpile system wiring setup.0 -
No switch
No switch will be added...
Thank you!0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
