radiant w/ baseboard woes
rofey
Member Posts: 5
We have a new home with a combination of radiant heat under concrete, wood or tile and baseboard in carpeted rooms. (4 rad. & 4 bb) The problem is that we actually get too much heat in our baseboard rooms even when their thermostats are not calling for heat. It's not constant, but the spurts can push the temp between 5 and 10 degrees higher w/o the thermostat calling at all. There are check valves on the lines and check valves in the pumps. The domestic water is fed off the boiler to a water tank and though the temp is set low, the tap water is really hot. Through shutting off a zone at a time, we haven't been able to isolate one zone as the problem zone. Obviously we're burning more propane than we'd like. The radiant rooms seem to be pretty consistent - a little above the set temp but only 2-3 degrees usually. They are mixed at approx. 140 degrees. Any suggestions would be really appreciated.
Baseboard
Are there 4 separate zones of baseboard or 4 rooms on a single zone?There was an error rendering this rich post.
Baseboard
Baseboard
Sorry, there are actually 3 separate baseboard zones and 4 separate radiant zones. (I was counting the line to the water tank earlier when I said 4.)0 -
Baseboard
Are all three baseboard zones overshooting?There was an error rendering this rich post.
Yes I have noticed all 3 overshoot but not always at the same time. There have been times when I've found only 1 and times when its been all 3.0 -
New Home
When you say "New Home" do you mean that you have a newly built home or an older home that is new to you? If it's a "New Home" where is the heat loss and the radiant design? Can you post some pics of the boiler piping and the install?There was an error rendering this rich post.
