weil-mclain ultra 80
siteman
Member Posts: 5
I have a weil-mclain ultra 80 boiler and it has started to make a squeeling noise which sounds like it is coming from out of the blower motor and it started after I had to manually reset it from a hard lockout,can any one tell me what might be going on thanks
Gas Valve
When does this noise happen? I have had several of these where the gaskets where bad and caused a whining noise. Hard to tell when I can't hear it though.There was an error rendering this rich post.
How old is the unit?
Has it had annual maintenance? Do you have the I and O manual handy? What Series is it 1, 2 or 3? Do you know where the air silencer is located, if so check to make sure there is no blockage.0 -
If your I&o manual is not handy,
I do not know about Ultra 1, but the others are:
Ultra 2:
http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/discontinued/discontinued-boilers/ultra-series-boiler/ultraboilermanual.pdf
Ultra 3:
http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/boilers/gas-boilers/ultra-series-3/ultra-series-3-boiler-manual.pdf
Ultra 3 UE:
http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/boilers/gas-boilers/ultra-series-3-ue/ug3_boiler_manual.pdf0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
