Removing a section from the radiator
dbeswe01
Member Posts: 3
We would like to remove a section of the radiator to better fit the space it will be used in. Any tips on how these come apart? Made by American Radiator.
Thanks!
Thanks!
Removing Sections:
You can do it on modern radiators but that is not a modern radiators. I don't know of anyone who is a professional who would attempt that and guarantee results. You can try it if you like but I doubt that IF you get it apart, and IF you get it back together, it will be tight.
Good Luck to you or anyone trying to shorten it up. You'd be better off buying a radiator with the same EDR but smaller in width and higher in height.0 -
That is magnificent...
I agree with Icesailor, removing sections is an art especially on the older radiators. You might lose other sections in the process. Can be done, always some risk. That radiator is magnificent and seems just on the edge of needing a center foot section.
Good under-window radiator, that one.
A TRV, (thermostatic radiator valve), will serve to tame capacity if it is too much for the space. For steam, I like the Macon "OPSK" model. I presume this is team from the category of question.
Understanding your motive is more of a "fit" issue, to save space, the TRV could be installed with small brass tubing to extend it to a clear area."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Radiator:
If that radiator is around 18" high, it is probably around 3 Sq Ft or 25 sections or 75 Sq Ft.0 -
i have done it
I did a tall one, about 28" high that was about 10" wide. Had 2 threaded rods up top and 1 down the middle at the bottom. It was 11 sections and I made it to 7 sections. I used mega lock on the sections and it dripped a few drops the first couple heating cycles then held tight. I was able to use the threaded rod to really tighten up the rad sections. This one in the pic looks to have no threaded rod holding it together so I wouldnt even attempt to touch it. And its really big too, def better off finding a relacement radiator IMO0 -
Where to buy
Where can you purchase steam radiators? I've looked to upgrade in the past but haven't had much luck locating them.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
