drip return on one pipe
Epeter
Epeter Member Posts: 25
I added a drip return from the header (had been plugged).
Header and first sections of mains reverse flow...balance of mains parallel flow.
I piped it to the low point of the wet return.
 I now have water level and hammmer issues.
What is the correct location for the drip return to connect.
  • Rod
    Rod Posts: 2,067
    Need Pictures
    Hi- Post some pictures of the piping so we have a better idea of how it is configured.
    - Rod
  • Big Ed_4
    Big Ed_4 Member Posts: 3,344
    Post a Photo
    It would direct us to a solution .... First thought you may need it to trap it ..
