Kick space heater question
tness34
tness34 Member Posts: 1
Hi I'm trying to find a toe kick heater with 3/4" connections in and out, no monoflos just a straight 3/4" connection. Anyone know where I could find one?
  • Brad White
    Brad White Member Posts: 2,399
    Most
    I have seen are 1/2" connections. What is driving the size? A couple of increasers will send you on your way. Feed with 3/4" and reduce right at the unit.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • billtwocase
    billtwocase Member Posts: 2,384
    same here
    I have only seen 1/2", and I wouldn't tie them in series like you would a zip loop. Best to use the mono-flo T's
