Kick space heater question
tness34
Member Posts: 1
Hi I'm trying to find a toe kick heater with 3/4" connections in and out, no monoflos just a straight 3/4" connection. Anyone know where I could find one?
Most
I have seen are 1/2" connections. What is driving the size? A couple of increasers will send you on your way. Feed with 3/4" and reduce right at the unit."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
same here
I have only seen 1/2", and I wouldn't tie them in series like you would a zip loop. Best to use the mono-flo T's0
