Insulating Steam Header
NickM
Member Posts: 25
The header on my WM 88 series 9 section has no insulation
The pipe is 8.5" OD, about 7 feet long
What would be the best way to insulate it --- I can not find material like a fiberglass shell.
Regards
Nick
Regards
Nick
Insulation
Here are two examples Nick, do it yourself and professional. http://www.heatinghelp.com/forum-thread/132995/What-type-of-pipe-insulation-should-be-used-on-the-near-boiler-piping0 -
Will start this weekend
Thanks for the heads up
All you guys are great0 -
8" Pipe Size Fiberglass Insulation
If the OD is 8.5" you have a pipe that has an 8" Nominal Pipe Size. They make 8 x whatever thickness fiberglass you need and come in 3ft lon sections that would snap right on.There was an error rendering this rich post.
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
