Floor warming with forced air heat
Jack Smith
Member Posts: 53
New build with zoned forced air systems, floor warming for typical hard sufaces such as kitchen and bathrooms. Problem- Overheating kitchen area when trying to maintain warm floor. Questions- What surface temp. is generally acceptable for floor warming? Would a floor sensor be a better control strategy as opposed to using a two stage stat? Would adding a cycle timer be of any benefit? Any help would be appreciated!
Wirsbo 511s
Always use a a control like the Wirsbo/Uponor 511's. Its programable like a thermostat. It can do just floor sensing, air sensing or a combination of both. Also has teh ability to learn the cycles. It's a must when doing floor warming in my opinion.
Water temp would be based off a radiant design and heat loss. I would want to keep a 70 degree floor surface. But everyones comfort level is different.There was an error rendering this rich post.
- 87K THE MAIN WALL
- 111 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
