Taco relay help
Pietro
Member Posts: 1
I have a Laars mascot 2, 2 zones with taco 570 zone valves, 1 taco 007 circulator and a taco sr502 relay. Need help with the wiring please.
Thanks,
Pete
Thanks,
Pete
Question
What is your question? Do you have a wiring schematic?There was an error rendering this rich post.
Bad News...
Sorry to tell you but you have the wrong mult contol for your application.
SR relays are for multiple pumps- pump for each zone, not zone valves.
ZVC relays are for multiple zones using one pump and zone valves.
you would need a ZVC 403 control,
Here is a link to the Taco site and the ZVC control.
http://www.taco-hvac.com/uploads/FileLibrary/100-5.1.pdf0 -
Funny
Ha, I didn't read it close enough I guess. Eric is right, you need a ZVC 403. There is a way to get it to work but it may be more complicated than just getting the right unit for the application. Guess I better read closer.There was an error rendering this rich post.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
