Zone heating: one floor too hot
I recently had to change the thermocouple on my heater because the pilot light went out and would not stay on when lit.  When I turned on the zones (all separate electrically), my second floor overheated (thermostat set for 68 degrees, room temperature increased to 82 degrees).  I turned off all zone electrical switches to stop the furnace. Do you think this is a valve problem?
  • RobbieDo
    RobbieDo Member Posts: 130
    Hot
    I'm assuming you have a boiler, but then you say furnace? Is it a zoned forced hot air system? Is the stat working properly, have to check at set temp that the stat is opening the circuit?
  • Bernadette
    Bernadette Member Posts: 2
    Response to Hot
    Thank you for responding.
    Sorry for the confusion, it is a boiler for hot water heat (radiator).
    The first thing I did was check each floor's thermostat to verify the temperatures that turn on the heat.  Each floor was different.  However, I don't remember what the temperatures were, but do remember that the were in the 60s.
