Relay Keeps Sticking
elvisman
elvisman Member Posts: 3
I have a Valiant Gas fired boiler and the relay keeps sticking, it will open but not all the way so i have to manually open it a tad bit so the boiler will fire.. The AquaStat relay is Model# L8148E... Can that small relay be relaced or do i need a whole new control? Thank you for taking the time and consideration to read my post
                                                              Elvisman
  • TonyS
    TonyS Member Posts: 849
    Replace it
    Or it may stick when your not there and you will come home to frozen pipes.
    Here is a nice replacement and it has a heat manager program built in.
    http://www.beckettcorp.com/Product2/productdetail.asp?detailid=35
  • elvisman
    That Beckett Relay Contol is Bad-****
    There isnt a more simpler solution than replaceing the whole control? I mean thats 1 mean Beckett control but could maybe the contacts need to be cleaned up a bit? Just wanna try the obvious first before i purchase  anything?
  • Tim McElwain
    Tim McElwain Member Posts: 4,656
    That relay can
    be replaced with an Honeywell L8148J Universal relay. As was posted it could hang up again replace it.
