Uphill Return
I have been asked to do a job in a factory where they want to have some steam fin tube radiation installed at the bottom of an elevator shaft. The condensate return line is about 20 feet above the bottom of the elevator shaft. I was told that there used to be a radiator there and the steam was piped into the radiator and the condensate was piped back up to the condensate line without a pump. The piping is still there but the radiator has been removed and the lines are capped at the bottom of the elevator shaft. There is still a bucket steam trap up at the condensate return line right before it ties into the main condensate return. Is it possible that this could have worked? There is 20 pounds of steam pressure.
Thanks
