new cast iron smell
skifast
Member Posts: 2
Installed new free standing cast iron radiators 2 months ago and they still smell installed on steam boiler,
smelly rads
what sort of smell is there-chemical, petrochemical, paint, rotten?
are these newly made or just new to you?
some smells may come from the rest of the system. --nbc0 -
Gradual
I had a new cast iron baseboard installed almost a year ago and I still get a little smell but usually only noticeable when the full length of the baseboard is heated. The smell has gradually gotten better since installation..0 -
Smell will eventually go away
I installed a large cast iron radiator which I had constructed from 2 salvaged radiators, taken apart an reassembled as one. I painted it with dark bronze spray paint at the time, in January of 2009. When connected to steam it made a pretty strong paint off gassing smell. This subsided within the first week, but was detectable for quite some time. It was probably close to a year later before there was no detectable odor whatsoever. However, I have a pretty sensitive nose. The radiator is located in the entrance hall of a house/apartment conversion. None of the tenants complained or even commented.
I have had much shorter "smelly time" with other radiators painted with the same brand and color of paint.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
