new cast iron smell
Installed new free standing cast iron radiators 2 months ago and they still smell installed on steam boiler,
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    smelly rads
    what sort of smell is there-chemical, petrochemical, paint, rotten?
    are these newly made or just new to you?
    some smells may come from the rest of the system. --nbc
  • ansky
    ansky Member Posts: 41
    Gradual
    I had a new cast iron baseboard installed almost a year ago and I still get a little smell but usually only noticeable when the full length of the baseboard is heated. The smell has gradually gotten better since installation..
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Smell will eventually go away
    I installed a large cast iron radiator which I had constructed from 2 salvaged radiators, taken apart an reassembled as one.  I painted it with dark bronze spray paint at the time, in January of 2009.  When connected to steam it made a pretty strong paint off gassing smell.  This subsided within the first week, but was detectable for quite some time.  It was probably close to a year later before there was no detectable odor whatsoever.  However, I have a pretty sensitive nose.  The radiator is located in the entrance hall of a house/apartment conversion.  None of the tenants complained or even commented.
    I have had much shorter "smelly time" with other radiators painted with the same brand and color of paint.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
