Motorized Damper Q
Steve_175
Member Posts: 242
in Oil Heating
I have a residential oil fired one pipe steam system in my house. New Hydrotherm boiler installed this summer. I was wondering if I had a motorized damper installed if it would help with the efficiency of the system and is it worth it?
no
motorized dampers are for gas boilers not I repeat not oil.Cost is what you spend , value is what you get.
cell # 413-841-6726
Thanks
for the clarification.0 -
Field brought out an oil-designed damper recently
the OVD series. One of these days I'll have to try one.All Steamed Up, Inc.
Consulting0 -
Got a link?
What is special about them to make them work on a oil fired boiler?0 -
Consulting0 -
Thanks
Do you think its worth it. Would you put one in your house? For that matter what do you think these things go for?0 -
they do
have stack dampers for oil fired units, Field makes them, Flair was popular back in the late 70's early 80's. They do help reduce the stand-by temp loss.0 -
I guess I stand corrected
Those Flair installs left a bad taste in my mouth. Of course it may have been the installers. Bill do you install many of these dampers? I am not a fan of sticking an electric damper on an oil flue.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 50 Industry Classes
