removal of heat trap/obstruction in water heater
Dan0
Member Posts: 3
I was told by a freind to remove the heat trap from the HOT end of my water heater, as its an obstruction, cap off the COLD on the top of tank & return the water through the bottom drain this is for a hydronic heat project, I will be mounting a expansion tank/air seperator on the discharge & its a closed system being staple up floor panels, using a 007 Taco pump.
Lemme get this straight....
You want to use a tank style water heater to do space heating? Is it doing your DHW as well. or only dedicated space heating?
If it is dual use, is there a heat exchanger between the two functions, or contiguous water?
ME0 -
sorry for the confusion
this is a closed system, seperate of my house hold WH, this is a DWH for my floors only for comfort. Note: I have the same system in my 960 sq ft garage & have had no issues in the past 9 years, but that does not tell me weather on not the trap should be removed, thanx Dan0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
