Richardson system and air expeller
Dennis Foley
Member Posts: 21
I am restoring a Richardson system, with the ball check return elbows. Some of the balls are missing, but I have found replacements. I will have to add a few steam traps on radiators that have been messed with.
My question is about the air expeller. I assume that it had a check valve, since the Richardson system was a vapor vacuum system.
Have any of you come up with a way to have a main air vent with a check that works to form a vacuum in the returns?
yes, but do you really
want to do vacuum on the system unless its coal..gwgillplumbingandheating.com
Why not share?
Would you mind sharing what you've come up with?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
