PH sensor
Steve_210
Member Posts: 664
Does any of the condensing boilers have a built in ph sensor. If not can anyone recomend one that could be added to the piprwork.
Why ?
DISCLAIMER I AM NOT A HEATING OR PLUMBING PROFESSIONAL
"Does any of the condensing boilers have a built in ph sensor. If not can anyone recomend one that could be added to the piprwork. "
Which fluid stream do you want to monitor and why?0 -
if the boiler
has an alumium heat exchanger you need to moniter the PH levels0 -
I am not a professional.
I do have a pH meter that I use once in a while to measure pH of things, like photographic solutions. It works on my boiler too, but I do not believe it would make sense to install a well somewhere in the system and leave the meter in there. One problem is the meter is very temperature sensitive, even though it is claimed to be temperature compensated. I know if I calibrate it at 70F and measure the water at 120F, the readings are way off. Furthermore, if I calibrate it one day, it is off the next even at essentially the same temperature. It works fine under static conditions where it can be calibrated. But as an operating device, I would forget it. Also, I do not know how long the probe would last in a continuous duty situation.
As long as your system does not leak, I would not expect its pH to change very quickly. So flush out your system, put in fresh water, measure the pH and put some Sentinel or Rhomar soup in there as directed, and assume it will buffer the pH from one annual service to the next. I think if you want to add something to your boiler, a small water meter would be more helpful, because it could warn you of leaks.0 -
thanks
i read a post earlier where a dripping relief valve went unnoticed and ruined the HX.
I thought it would be a nice feature so the customers could monitor it themselves but i guess they can do that with a water meter. I wasn,t aware of the temp issue0
- 50 Industry Classes
