Where to get new Spuds w/ union?
Nebraska
Member Posts: 3
I lost all of male sides of my unions that connect my radiators when demo-ing my house. Didn't think about keeping them because I thought they wouldn't come apart anyway. Well, I then discovered a "spud" is normally used (with small keys on the ID of the spud which is the point of a spud wrench) instead of standard pipe nipples to connect to the radiator.
I have asked all over locally, and also haven't seen anywhere online to get new spuds. Anyone know of somewhere?
You need to buy
Radiator valves. They do not come as separate pieces.Cost is what you spend , value is what you get.
cell # 413-841-6726
Return Side Union?
Thanks Charlie. What about on the return side of the radiator? There is a valve on the supply side, but not the return side. Do they come together as a kit (2 unions together as a kit)?0 -
Valves
I have never seen a kit offered with a valve and a radiator return ell. Your best bet is to get new valves and radiator return ells as charlie stated. Even if you could get new valve nipples and unions it is very unlikely they would seat properly, especially if you have old valves, and you would likely be stuck with drippers at every union.0 -
Thanks
Thanks JharrisSeattle. Finally when I searched for "Radiator Return Ells" then I found what was needed. I just didn't know what they were called. Thanks.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
