increasing humidity
Irv
Member Posts: 95
In past threads, I saw a vessel for adding water that hung on steam radiators
to increase humidity in the room. A nicer alternative to putting a pot of water on top. Does anyone recall the resource?
thanks.........................
Radiator Humidifier
Hi Irv- Here is a website where they sell radiator humidifiers.
- Rod
http://kilian.stores.yahoo.net/radhum.html0 -
humidity
Thanks...........................0 -
My grandfather's house had steam heat.
Their radiators had humidifiers on the same principle as the ones in the pictures. But the little reservoir on his were the size of a large soup can (about double the size of Campbell's Tomato Soup), so they held more water than the one in the picture. Those had a piece of felt in the part inside the radiator that wicked water up to get more evaporation. I cannot recall if the felt touched the fins of the radiator or not, but I suppose it did. They did not drip on the floro, though. Main problem is they sometimes forgot to fill the things.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
