need hlp with heat loss
heatmizer
Member Posts: 14
I got 14 year as hvac tech,Just starting to learn little steam today was talking about sizing new boiler for existing systems .Was told that the old systems where sized about 75% to big at the time most these where being installed and that all the radiators are over sized about the same . then was told i would size the new boiler to the old radiators ,and i know i can control the radiator to control the heat ,but why would i size to radiator knowing there oversized .??? And if anyone has a good heat loss formula for steam would love to see it .
Steam Books
Hi- There are some really good steam books ( and others on hvac) in the Shop section at the top of this page. Probably you'd want to get "The Lost Art of Steam Heating"
http://www.heatinghelp.com/products/Books/Books-by-Dan-Holohan/11/68/Lost-Art-Of-Steam-Heating
Another book that might be of help to you is the Burnham Heating Helper. You can down load a copy at this link.
http://www.usboiler.burnham.com/PDF/htghelper.pdf
- Rod0
