Stainless Steel Air Separator
Salesguy
Member Posts: 5
Please give me the name of a manufacture that makes a 1-1/4" STAINLESS STEEL air separator.
do you need just 1?
or an on-going orderBob "hot rod" Rohr
S/S?
What do you need a stainless air seperator for, out of curiousity? The only ones I know of are brass/bronze.There was an error rendering this rich post.
Reply
I need just one for closed process system that is filled with demineralized water.0 -
Reply
I need the stainless steel seperator for a closed process system that is filled with demineralized water. It operates just like a closed hydronic system, except the water is cooling heat exchnages on some machines and the syetm is filled with demineralized water.Yes, I know all I can find is brass and bronze ones.
Thanks for the reply.
What size?
If you just need one, have a stainless steel fab shop build one. You can but the stainless mesh for inside if you want air elimination also. McNicholas in Chicago sells that.
Here is a cool "corner" version that a pipe fitter over towards St Louis build, and posted here a few years back.
Let me know I have all the dimensions and know a few fab shops in my area that could build one.
What's in you wallet
hrBob "hot rod" Rohr
