Stainless Steel Air Separator
Salesguy
Salesguy Member Posts: 5
Please give me the name of a manufacture that makes a 1-1/4" STAINLESS STEEL air separator.
    hot_rod Member Posts: 26,607
    do you need just 1?
    or an on-going order
  • SpeyFitter
    SpeyFitter Member Posts: 422
    S/S?
    What do you need a stainless air seperator for, out of curiousity? The only ones I know of are brass/bronze.
  • Salesguy
    Reply
    I need just one for closed process system that is filled with demineralized water.
  • Salesguy
    Reply
    I need the stainless steel seperator for a closed process system that is filled with demineralized water. It operates just like a closed hydronic system, except the water is cooling heat exchnages on some machines and the syetm is filled with demineralized water.Yes, I know all I can find is brass and bronze ones.
    Thanks for the reply.
    What size?
    If you just need one, have a stainless steel fab shop build one. You can but the stainless mesh for inside if you want air elimination also. McNicholas in Chicago sells that.
    Here is a cool "corner" version that a pipe fitter over towards St Louis build, and posted here a few years back.
    Let me know I have all the dimensions and know a few fab shops in my area that could build one.
    What's in you wallet :)
    hr
