White-Rodgers thermostat - heat pump mode setting
Dogstar
Member Posts: 5
The White-Rodgers 1F95-1291 thermostat, in heat pump mode, supports two system switch configurations :
1. Cool-Off-Heat-Em-Auto (* factory default)
2. Cool-Off-Heat-Em, Off-Em-Auto
Ultimately I would like the thermostat configured to offer the most versatility for my 3H/1C heat pump system. Needless to say I'm having a brain fart today deciphering the setting difference. Care to explain, please?
Thank you. Dogstar.
Thank you. Dogstar.
Good t'stat
That is fan on/auto on that other switch. And this tstat is for up to 4h/2c. Getting it set up is up to you now0 -
Thermostat switch selection
Thank you, sounds like the factory default switch configuration (Cool-Off-Heat-Em-Auto) is sufficient then. And you're right, this thermostat supports up to 4H/2C heat pump systems. Deciphering the installation manual, with my single-stage heat pump (HP1) setup I'll only get 3H/1C settings?0 -
Stages
You can have 4 stages of heat ,or more than likely you will have 3 stages of heat. H.P. 1st stage, 50% of electric heat for 2nd stage and 50% of electric heat for 3rd stage .0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 998 Plumbing
- 391 Solar
- 55 Water Quality
