Automatic Filling Gauge is spewing water
I went into the garage tonight to find it flooded.
We have an emmeti automatic filling valve with gauge and it was spewing water from both sides of the black cylinder on top. There was an adjustable screw underneath that when I turned it fuilly clockwise to close it, the water stopped.
I'm not sure if that was the correct thing to do?
I've attached photos.
Please let me know - I hope there is someone out there on the site as it is Stephens night!!
  • kcopp
    kcopp Posts: 4,718
    I have not.....
    seen that model fast fill before... Are you n the UK? as you mentions st. Stevens/ boxing day....
  • Fittings
    I'll bet he is in Europe by looking at the fittings. Male by male ball valve.
  • Yes I'm in Ireland.
    I'm not sure what you mean by fast fill?
    Basically the heating has been working fine since I tightened the valve underneath but I was wondering why it spews water when I unscrew it and is it ok that it is now shut tight?
  • feeder valve
    Do you have a pressure gauge on the boiler? AS long as that is the on/off wheel you turned and  you stopped the water it should be OK, you'll need to keep a watch on the boiler pressure, if there are any minute leaks you will lose pressure and heat to the highest points. But if the water level gets low in the boiler then you could have problems. I don't know what boiler you have. With the separate feeder valve I'm assuming it's not a wall mounted unit. As long as your not overfeeding the system you should be OK till you get a replacement.
  • Da
    Da! Were  in the oil section. It's probably an oil boiler. There should be a gauge on the boiler keep a watch on that. We turn the water feed off when we add anti-freeze and they run trouble free for many years.  Keep an eye on the feeder valve that it doesn't start leaking from the opposite side. I don't know how that is made. The diaphragm or seal was probably letting the inlet side water by and could continue to deteriorate till it lets the boiler water start to leak out. Maybe change it at the end of the season.
  • do you have a name
    on that valve? I could look for a manual and give a better answer. My family left Ireland in the 1840's for the sunny clime of Glasgow for a few generations before coming to the States. My Da spent his summers after the war at his sisters near Black Lion.
    cell # 413-841-6726
  • The gauge on it is quite high.
    I think it is back flowing you need to have that looked at as the black needle is almost pinned all the way around. It should not be reading any higher than the red needle. Is there a valve between that valve and the water supply? I am thinking water expansion tank needs replaced or serviced also
    cell # 413-841-6726
