wet steam
I'm hoping some of you can help. I am having problems with wet steam and water actually coming up the pigtail and stopping my pressurotol from operating correctly. I have tried everything that I can imagine:
1) Repiped near boiler piping correctly
2) Skimmed boiler
3) Cleaned/Flushed boiler about 8 times
I'm at a loss at how to stop this from continuing. Any thoughts or advice would be helpful.
  • Rod
    Rod Posts: 2,067
    Wet Steam
    Hi-  At what pressure is your system running? It should be 2 PSI or less. You might also post some pictures of your boiler and near piping and maybe we can see something that might be causing the wet steam.
    - Rod
  • wet steam causing cut out?
    what height is the pressuretrol mounted at?
    the pigtail could have some debris in it trapping the water with a bit of pressure.
    if mounted too low and the waterline gets a bit elevated, it could pressurize the pressuretrol beyond the cut-out point. an accurate gauge [0-2 psi, gaugestore.com] would show your exact pressure when this cutting out occurs.--nbc
