Pressuretrol Setting on Burnham
Pressure
You can bring that pressure setting down even more. The system only needs ounces. The lowest setting .5 is generally where we set them. I would also recommend a brass pigtail. Actually Brass is required by code now.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
