Pressuretrol Setting on Burnham
Pressure
You can bring that pressure setting down even more. The system only needs ounces. The lowest setting .5 is generally where we set them. I would also recommend a brass pigtail. Actually Brass is required by code now.0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
