Ugly radiators
JoeE
Member Posts: 1
I'm an architect trying to replace a traditional (and old) steam radiator in a shower room. I'd like to install something more stylish than anything I've found. while some options appear available in hydronic systems I can't find anything in steam. I'm looking for a more sealed smooth face because of the location.
Joe
Joe
Existing Radiator?
Hi,
Is existing radiator on the ceiling, wall, or setting on the floor? There is really no such thing as a traditional radiator, because they came in so many styles, shapes, and designs.
If it is going to work on a steam system, it needs to be made out of the same materials as the rest of the radiators in the system. That is, if the rest of the system is cast iron, and you put in a radiator with low mass, it will not function the same, the people in the shower will be cold and VERY unhappy with their "attractive" radiator.
Do you have any pictures of the current radiator and how it is installed? If so, please add to the post.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Sunrad
See if you locate an old ARCO Sunrad or a new Burnham Radiant. These can be recessed into the wall. I have a Sunrad in my bathroom and it looks great. I would use cast iron rads on a steam system.0 -
or governale
govray1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Heres some choices and a place to get them
http://www.radicalradiator.com/index/Finding+a+Radiator Note the wall hungs. Get them powder coated for a solid surface that stays nice.Cost is what you spend , value is what you get.
cell # 413-841-6726
Also
when it comes to comfort nothing about a cast iron radiator is ugly!Cost is what you spend , value is what you get.
cell # 413-841-6726
Try....
steamradiators.com. They have the modern "european" style radiators for steam.There was an error rendering this rich post.
Electric Radiant Heat is the way to go in a shower room
Instant and on-demand with the advantages of steam radiation plus towel warmers. No, I don't work for the electric company :-)0 -
I've Never Seen an Ugly Radiator....
I've been thinking about it all day, and for the life of me, I simply cannot recall ever seeing a cast iron radiator that I thought was ugly. Of course, I have seen a few that needed to be sandblasted and repainted.... But that is just condition. Cast Iron Radiators, in and of themselves, are objects of beauty, in my eyes.Dave in Quad Cities, America
I wouldn't use electric
in a shower room of all places! Sooner or later something will get wet that shouldn't, and someone could get hurt.All Steamed Up, Inc.
Consulting0
