Ugly radiators
JoeE
JoeE Member Posts: 1
I'm an architect trying to replace a traditional (and old) steam radiator in a shower room.  I'd like to install something more stylish than anything I've found.  while some options appear available in hydronic systems I can't find anything in steam.  I'm looking for a more sealed smooth face because of the location.
Joe
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Existing Radiator?
    Hi,
    Is existing radiator on the ceiling, wall, or setting on the floor?  There is really no such thing as a traditional radiator, because they came in so many styles, shapes, and designs.
    If it is going to work on a steam system, it needs to be made out of the same materials as the rest of the radiators in the system.  That is, if the rest of the system is cast iron, and you put in a radiator with low mass, it will not function the same, the people in the shower  will be cold and VERY unhappy with their "attractive" radiator.
    Do you have any pictures of the current radiator and how it is installed?  If so, please add to the post.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Mark N
    Mark N Member Posts: 1,144
    Sunrad
    See if you locate an old ARCO Sunrad or a new Burnham Radiant. These can be recessed into the wall. I have a Sunrad in my bathroom and it looks great. I would use cast iron rads on a steam system.
  • jpf321
    jpf321 Member Posts: 1,568
    or governale
    govray
    1-pipe Homeowner - Queens, NYC
    NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
    installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
    Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
    my NEW system pics | my OLD system pics
  • Steve_175
    Steve_175 Member Posts: 242
    New Steam Rads
    www.steamradiators.com
    Not many choices for new steam rads.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Heres some choices and a place to get them
    http://www.radicalradiator.com/index/Finding+a+Radiator Note the wall hungs. Get them powder coated for a solid surface that stays nice.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
    Also
    when it comes to comfort nothing about a cast iron radiator is ugly!
    cell # 413-841-6726
  • Try....
    steamradiators.com.   They have the modern "european" style radiators for steam.
  • haaljo
    haaljo Member Posts: 112
    Electric Radiant Heat is the way to go in a shower room
    Instant and on-demand with the advantages of steam radiation plus towel warmers. No, I don't work for the electric company :-)
  • Dave in QCA
    I've Never Seen an Ugly Radiator....
    I've been thinking about it all day, and for the life of me, I simply cannot recall ever seeing a cast iron radiator that I thought was ugly.  Of course, I have seen a few that needed to be sandblasted and repainted....   But that is just condition.  Cast Iron Radiators, in and of themselves, are objects of beauty, in my eyes.
    Steamhead Member Posts: 18,196
    I wouldn't use electric
    in a shower room of all places! Sooner or later something will get wet that shouldn't, and someone could get hurt.
    Consulting
